Hello , i have a tt engine droped in already in my 2+2 car,i will use my original 5 speed transmission from non turbo,the flywheel/clutch i planning to use are the twin turbo setup, so that beign said ,here's my question, is neccesary to grind a little bit the inside of the bell housing where the flywheel rotate? in order to fit that slightly bigger flywheel. Anyone done this w/out grind the housing??? thanks...
non turbo transmission modification - mapsz3210:55:46 06/29/12
